Activity Forums VEGAS Pro Video Renders into Pieces instead of one big file?
  • Video Renders into Pieces instead of one big file?
    Posted by Stephen Kendall on November 20, 2011 at 2:23 pm
    I am trying to render a 44 minute video into an .avi file. I have renderd tons of shorter videos (5-10 mins) with no problem. However, when trying to render this bigger movie it gives me 3 seperate .avi files for the 1 project. Is there a limit on the size of the file it outputs?
    Thanks for any help on this!
    Stephen Kendall replied 14 years, 9 months ago 3 Members · 3 Replies
  • Mike Kujbida
    November 20, 2011 at 3:25 pm
    My guess is that the drive you’re rendering to is formatted as FAT32.
    Change this to NTFS and your problems will go away.
  • Stephen Mann
    November 20, 2011 at 3:49 pm
    The only limits are the ones imposed by the file system – NTFS can address 16Tb files, which is large enough to hold every DVD title you own in one file.
    If the pieces are about 4Gb each then you are using a FAT-32 partition.
    Steve Mann
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Stephen Kendall
    November 20, 2011 at 9:40 pm
    Worked just like you said, thank you very much!!!!
