Video Quality Drop and other problems?
Hello,
I spent the morning editing a sequence – fixing the audio in Soundtrack Pro and then color correcting and rendering.Everything’s fine, except when I export it, the dimensions are incorrect. I thought it was an exporting problem, but I realized that there is something wrong with my sequence settings.
At full resolution, each of my clips are viewed at 24% (to fit the screen). The entire sequence dropped in quality, and is viewed at 74% in order to be the “same size” on my screen as the 24% clips from my camera.
Also, my other sequences that work fine don’t display black letterboxes within the video; they are simply cut off of the frame. In this problematic sequence, there are black stripes at off-frame areas in other sequences.
I tried imitating sequence settings, but it didn’t work – the entire clip shrunk in size, so that on the viewer, you see the video in a small box within a big black square.
I’m unable to identify the exact problem, and I understand it might be a bit misleading. But any information would be appreciated.
Also, I tried copy and pasting clips from this sequence into another one that worked; the clips are still in poorer quality and at a different size
