Activity Forums Adobe Premiere Pro Video quality
  • Video quality
    Posted by Kim Simms on January 10, 2010 at 11:35 pm
    My video looks great in the editor, but when I export to DVD, I can see movement whenever the camera moves. How can I get rid of this on the DVD?
    Kim Simms replied 16 years, 8 months ago 4 Members · 6 Replies
  • Bob Dix
    January 11, 2010 at 2:32 am
    I really think this is poor compression to DVD, trying going to Export to Tape, we find the result is a great improvement.
  • Bob Dix
    January 11, 2010 at 2:36 am
    When you compare even high definition reduced to DVD the artifacts (unwanted) appear in vertical and horizontal lines or other unwanted places, it may depend on computer power , not so to High definition tape.
    Export to Tape is very clean , worth a test ????????????
    Try Blu-ray ?????????????????
  • Bob Dix
    January 11, 2010 at 2:54 am
    You could try reducing the transfer rate to 7mbps ??????? you have probably done that ?
    If you are in Standard digital or high definition the look on the monitor may be slightly degraded but it should be perfect on the DVD or when played on a good DVD player to a good TV
  • Ann Bens
    January 11, 2010 at 10:55 am
    What is your source footage, project settings and output settings?
  • Brian Louis
    January 11, 2010 at 11:04 am
    [Kim Simms] “when I export to DVD, I can see movement whenever the camera moves”
    When you say you are seeing movement, are you talking about camera shake?? or artifacts??
  • Kim Simms
    January 18, 2010 at 11:05 pm
    It looks like the video is out of sync. The video looks find in the editor but on the dvd where there is movement like panning, the video appears to be out of sync like a ripple effect.
