Activity Forums Apple Final Cut Pro Legacy Video Processing
  • Video Processing
    Posted by Pato Kei on January 13, 2008 at 4:39 am
    Hi
    I am working on a MPEG IMX 50 sequence and I would like to know if the video processing settings are OK. I am rendering in 8-bit YUV and, Precces Maximum White is WHITE and Motion Filter Quality is BEST. Is this OK?
    thanks in advance and excuse my english
    Paul Escandon replied 18 years, 8 months ago 2 Members · 3 Replies
  • Paul Escandon
    January 14, 2008 at 5:08 pm
    Those settings sound good to me. Unless you have a specific need to render as high-precision YUV and find 8-bit satisfactory, then I think you should have no problems there.
    The motion filtering quality set to BEST is going to give you better renders if you’re animating movements or positions than if you had it set to NORMAL, so that’s good.
    Paul Escandon – Lead Editor @ Outdoor Channel
    Producer | Director – Oremus Productions
    http://www.oremusproductions.com
    Apple Certified Trainer – Final Cut Pro
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Pato Kei
    January 14, 2008 at 5:15 pm
    and what about Super White? I am rendering in White now
    thanks
  • Paul Escandon
    January 14, 2008 at 5:53 pm
    Unless you have a specific need to preserve the superwhite values (from 100% to 109%) then you can keep the setting to white. It’s totally up to you. It may not really matter depending on what your requirements are.
