Video Playback problem – Only with one particular Sequence
Hello to all,
I am editing at a clients office and can’t seem to figure out this problem with video playback. There system is a Mac Pro Quad, 8gigs, with FCP S2. The footage is all DVCProHD 720p24 shot from the Panasonic HDX900. I am using the Panasonic BT-LH900A Monitor (I call it the little 8.4inch). This is all through an AJA Kona Card (not sure which model).
For some reason, the biggest project that I am working on, less the 7min, will not let me monitor picture in real time. I can scrub the picture (slowly), but once I press the space bar and play, the monitor will FREEZE on the last frame and hold. Then once stop or pause, the monitor will refresh with the current frame.
This is only on this particular sequence (the 7min piece), every other sequence looks great. The previous editor organizes quite different than I would of, there are 28 different spots in the same project. Not sure if that has any thing to do with it. Everything is rendered. I just don’t know.
Let me know if anybody has any suggestions or have experienced the same problem.
Thanks in advance for your help,
Beau
