Activity Forums Apple Final Cut Pro Legacy video playback out of sync.
  • video playback out of sync.
    Posted by Joshua Spool on December 5, 2011 at 1:45 pm
    I recently took a new job at a post house and Instead of using professional external monitors for viewing, they’ve taken to using these SONY bravia LED TV’s. The problem I’m getting is that the video that plays on these monitors is off by about 2-3 frames. However the video that plays on my reference monitor is frame accurate. The engineer who set up my suite ran HDMI into the SONY. While it runs SDI into my reference monitor which works fine. I’m wondering if the offset has to do with the HDMI? If I run component into the TV will that solve this issue?
    Joseph Hung replied 14 years, 9 months ago 3 Members · 2 Replies
  • Brad Wright
    December 5, 2011 at 2:38 pm
    Are you running the audio to the HDMI, as well. Usually, this problem happens when you send the audio and video to different destinations. Make sure your audio and video are going to the same television monitor.
    Brad Wright is software engineer, so it may be difficult to understand what he is saying. He is always happy to explain his greater detail.
  • Joseph Hung
    December 5, 2011 at 4:46 pm
    It’s the HDMI. I run audio and video separately, so I don’t know if the above comment will work, it might give it a shot. One way to fix this is to offset your video feed by a few frames. When I play video to my client viewing HDTV I have to offset it by 5 frames to have the audio playing separately through a mixer and monitors to be in sync with the HDTV. It’s not perfect, but it’s pretty darn close.
    Go to System Settings, then Playback Control, then Frame Offset. You’ll have to play with it to find the right number of frames.
    http://www.tulpapictures.com
    Twitter: @tulpapictures
    Facebook: http://www.facebook.com/tulpapictures
    Mac 2.66 GHz Quad Intel Xeon
    OSX 10.6.8
    FCS2
    CS5
    8GB RAM
    ProAvio 8TB RAID 5 Dual Mini-SAS
    Blackmagic Intensity Pro
    ATI Radeon X1900
    RocketRAID 4322 via dual MiniSAS
    Panasonic Lumix GH2, Canon 5DMKII, 7D, Panasonic HVX200A, Panasonic DVX100A
