Activity Forums Apple Final Cut Pro Legacy Video Playback is Glitchy. Can’t figure it out.
  • Video Playback is Glitchy. Can’t figure it out.
    Posted by Jordan Schevene on February 3, 2009 at 6:49 pm
    Thanks for ready this post.
    I was sent a hard drive with DV NTSC video on it. After importing it into FCP it plays back with glitches in it.
    I tried converting to Prorez422 in compressor but still get the glitchy playback in FCP.
    I tried converting to DV NTSC in compressor and it works fine. I would much prefer to edit in Prores422.
    This is the info from QT inspector of original DV clip.
    DV, 720 x 480 (640 x 480), Millions
    DV, Stereo, 32.000 kHz
    29.97
    57.54 mbits/s
    640 x 480 pixels
    Any ideas?
    thanks
    Jordan
    David Roth weiss replied 17 years, 7 months ago 3 Members · 2 Replies
  • Rafael Amador
    February 3, 2009 at 7:02 pm
    Hi Jordan,
    there are many reasons why your DV video may plays glitchy but you don’t go to improve things by converting it to ProRess. Probably you will have even more problems.
    You may want to edit your DV footage and export as ProRess, but convert to ProRess just like that makes no sense at all.
    BTW, what kind of HD are you talking about?
    Download the JA System Test software to check your HD speed.
    Cheers,
    rafael
    http://www.nagavideo.com
  • David Roth weiss
    February 3, 2009 at 7:35 pm
    More than likely it’s the 32khz audio that’s creating the issue.
    Open a new seq. – change the settings to DV and change the audio to 32khz, now drop one of the clips in and see if it doesn’t play smoothly.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
