Activity Forums Apple Final Cut Pro Legacy Video playback form external monitor only shows freeze frame
  • Video playback form external monitor only shows freeze frame
    Posted by Steven Worsley on September 9, 2008 at 2:24 pm
    I am trying to use a HDTV as a playback device through DVI and Final Cut’s video playback. I managed to get it to work, however it has now stopped working and only produces a still frame. When I hit play it will play fine in the timeline but displays only a still frame on the second monitor. I have made sure that the settings under video playback are set to full screen and that ‘all frames’ is selected.
    Even when I play back on Main the image on the main monitor only displays a still frame until the second monitor is unplugged.
    Am I missing something?
    Antonio Antonio replied 14 years ago 6 Members · 5 Replies
  • Shane Ross
    September 9, 2008 at 7:00 pm
    VIEW>EXTERNAL>ALL FRAMES?
    Shane
  • Ken Summerall
    September 9, 2008 at 7:53 pm
    Mine did this a few weeks ago and all of my settings were correct as well. A good old fashioned shutdown and restart seemed to fix the issue.
    K
  • Michael Orlansky
    September 9, 2008 at 8:19 pm
    Check your sequence settings too, specifically your aspect ratio, pixel aspect ratio and Compressor settings. I’ve noticed weirdness like that too with an external monitor and those settings were changed incorrectly.
    Mike
  • Michael Gissing
    September 10, 2008 at 3:09 am
    A mismatch between sequence settings and your Easy Setup settings will cause this behaviour with a Decklink card. However, hooking and HDTV via DVI – who knows. It is certainly not a recommended way to externally view as issues like correct display of interlace and color balance will be a problem.
    If your HDTV has HDMI, then a Decklink intensity card might be a much better option. An alternative is the Matrox MXO. A search of the COW forum will bring up Shane Ross’s article.
  • Antonio Antonio
    September 5, 2012 at 2:33 pm
    Hey, i had the same issue: the second monitor only showed the stopped frame.
    I solved it going on “Final Cut Pro”>”Audio/Video settings”>”A/V devices”, there you should check “mirror on desktop”.
    hope it helps you out.
