Activity Forums Adobe After Effects Video output
  • Steve Roberts
    July 21, 2007 at 9:05 pm
    Without buying a card such as the Decklink or AJA, you could hook up a camcorder to your Firewire port, then hook up the camcorder’s A/V out to a TV set. For more info on the preference settings, check the help.
    The Decklink/AJA cards give better results, though.
  • Scott Roberts
    July 22, 2007 at 7:08 am
    You can also use the Canopus ADVC-110, ADVC-300, etc., connected to your computer via firewire, then from there out to a monitor via RCA, or S-Video, etc.
    Color Grading presets for After Effects, Premiere, etc., plus free presets and more.
    LITTLE BLACK BIRD – PROFESSIONAL VISUAL EFFECTS
    https://www.littleblackbird.com
