Activity Forums Adobe After Effects Video output
  • Video output
    Posted by Andres Bocan on July 21, 2007 at 4:51 am
    Does anybody know what do I have to have and which connections I need to have a video output of my comp windows to see in real size the compositon I am doing it ?
    Kevin Camp replied 19 years, 2 months ago 2 Members · 1 Reply
  • Kevin Camp
    July 23, 2007 at 3:26 pm
    you’re asking about setting up ae to output to a broadcast monitor to get a more accurate depiction of color, aspect ratio and field rendering in ntsc (or pal), correct?
    there are several ways… most people have a pci card or similar device (like those from aja and blackmagic) that will give the computer various video connections that can be connected to a broadcast monitor and decks. these setups can get pricy.
    on the cheaper side, you may be able to get a device that will connect to firewire that will convert it to a video signal that can be connected to a standard tv. you can set ae to use firewire to monitor previews. i haven’t tried this, but i think it should work, note… it won’t be as accurate as a professional broacdast monitor.
    you could also directly connect a firewire monitor (or even camera) and set ae to monitor in a similar way as above.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
