Activity Forums Adobe Premiere Pro Video on Program Monitor seem smaller in size
  • Video on Program Monitor seem smaller in size
    Posted by Boon Ong on July 12, 2010 at 8:57 am
    Hello all,
    I have a question on my video shown on program monitor.
    Why does it seem to be smaller than have it full size covered?
    Because when I did the export, the outcome appeared to have the black screen on sides, top and bottom as well.
    Is there anything I should take note of?
    Please advise,
    Thanks.
    Boon
    Brian Louis replied 16 years, 1 month ago 2 Members · 5 Replies
  • Brian Louis
    July 12, 2010 at 1:34 pm
    [Boon Ong] “I did the export, the outcome appeared to have the black screen on sides, top and bottom as well.”
    The video probably doesn’t match the project settings. What kind of video are you using, get something like “g-spot” and check the video and see what the parameters are, and what are your project settings?
  • Boon Ong
    July 12, 2010 at 1:44 pm
    Project open: PAL Widescreen
    Video: 16:9
  • Brian Louis
    July 13, 2010 at 7:48 am
    That is your project settings, what are the video Parameters per g-spot
  • Boon Ong
    July 13, 2010 at 8:27 am
    Sorry, what does Parameters per g-spot means?
  • Brian Louis
    July 14, 2010 at 4:43 am
    g-spot is a small program that can be downloaded from the internet for free that will take most video and identify its parameters.
