Activity Forums Adobe After Effects Video Not Synching With Music
  • Video Not Synching With Music
    Posted by Gabriel Landeskog on February 12, 2011 at 6:11 am
    Ive Shot a 3 Min Music Video 1080p 24fps video edited with FCP and Exported as quick time movie with the same settings, but i chopped it up into 20-30 sec clips so after effects wouldnt have such a long vid (its my first time, Is this the correct way to do this
    ?)where i need to add my effects. but when i tried to bring 2 finished rendered ae clips back into final cut to put back together my clips dont synch with the song, i edited a full version without effects from final cut pro and its synched perfectly, so putting back together the clips should just simply match up. but it doesnt work. HELP!
    Gabriel Landeskog replied 15 years, 6 months ago 2 Members · 5 Replies
  • Angie Taylor
    February 12, 2011 at 4:08 pm
    Hi there,
    Have you run the latest updates for AE CS5? there was a syncing issue in 10.0.0 but it’s been fixed now so running Software Update from the Help menu may be an easy solution for you. If you run the update and still have problems you may want to check that the frame rates are indentical in FCP and AE.
    Hope this helps!
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
  • Gabriel Landeskog
    February 12, 2011 at 8:43 pm
    Im using the macs at my college I doubt I even have the ability to update it (they lock settings with admin restrictions etc)
  • Gabriel Landeskog
    February 12, 2011 at 8:47 pm
    I think your onto something ill try to export it properly. but i have a few questions
    1. should I be compositing effects with the full video or my little chopped up clips?
    2. when you say pull down do you mean the sequence itself in FCP?
    but thanks i really think your onto the problem
  • Gabriel Landeskog
    February 12, 2011 at 10:15 pm
    when i try to remove the pull down it says “file does not contain DVCPRO, DVCPRO-HD or DVCPRo-50 NTSC video”
  • Gabriel Landeskog
    February 13, 2011 at 8:00 am
    I ended up exporting everything from FCP as prores 422 HQ and into AE where i did everything i needed too, I exported It as a prores from AE with audio and viola its good. thanks for the help.
