Activity Forums Apple Final Cut Pro Legacy video not in sync on external monitor
  • video not in sync on external monitor
    Posted by Carpjen on October 2, 2007 at 1:15 pm
    Hi-
    I have Final Cut Pro 4, with the computer hooked to a DVCAM deck via firewire. The deck is hooked up to an external Sony NTSC monitor via BNC cables. When logging and capturing, I can see the video on the external monitor and it looks fine. However, when I playback video from the timeline, the video on the external monitor is out of sync- it looks like there are rainbow colored bars moving across the screen from left to right, and the picture is all swirly (not a great technical description I know). I checked the suggested settings in FCP and they seem ok, except that I could not find the option to View- Refresh A/V Devices in the menu list. If anyone has any ideas on what I should be looking for, don’t know if it’s the deck or the monotor or FCP, I’d appreciate any input. Thanks!!
    Rob Forsythe replied 18 years, 11 months ago 4 Members · 4 Replies
  • Steven Gonzales
    October 2, 2007 at 2:07 pm
    If you are hooked up via component video (3 cables) I would think the cables are not connected to the correct inputs on the TV.
  • Carpjen
    October 2, 2007 at 2:21 pm
    Hi-Thanks for the quick repsonse.
    I am not hooked up via component video.. only a BNC cable going out from the deck, into the NTSC monitor input A. Does FCP need component video to work?
  • Jeff Carpenter
    October 2, 2007 at 3:00 pm
    You know that the connection between the deck and the monitor is fine since it displays tape playback correctly.
    So the problem is between Final Cut and the Deck. What we don’t know is if this is Final Cut’s problem or the deck’s problem.
    First, check the menus in the deck. Is there any kind of NTSC/PAL issue? Does it have anything related to firewire or iLink? Check any settings that mention A/V input/output.
    In Final Cut, make sure that your device setup is firewire and not something else strange. Try restarting the computer with the deck connected and on. Look around at the last 3 or 4 items in FCP’s VIEW menu. Examine all of those and toggle things on and off.
    Those are the ares to start with, anyway.
  • Rob Forsythe
    October 2, 2007 at 3:15 pm
    This list contains virtually everything to try to enable:
    a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
    b. Viewing in the Canvas window on the computer screen.
    c. Being able to record on the external FW DV deck or camcorder.
    d. Being able to capture from a FW device.
    If working this list doesn’t cure the problem… you may have a serious PROBLEM!
    Try things in this order until you find the “cure”:
    1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
    2. Make sure you have View (Menu) > External Video> All Frames set.
    (If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
    3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen or “pushed into” other windows.
    4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
    5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
    6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
    7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
    8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
    9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
    10. Make sure you have chosen FW output for A/V:
    Final Cut Pro (menu) > Audio/Video Settings… >
    Video Playback: Apple FireWire NTSC (720 x480)
    Audio Playback: FireWire DV
    11. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
    12. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
    13. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
    14. Re-check that your FW cable is well-connected at both ends (or try a new cable).
    15. Important: Quit FCP, then Restart FCP.
    16. Now again, make sure you have View > External Video > ALL FRAMES set…
    If it still does not work. “Trash” the FCP Preferences on the Mac
    “FCP Rescue” is a free Apple Script that will Trash the Preferences.
    It will also restore your user settings afterwards.
    Download:
    https://www.macupdate.com/info.php/id/14729
    If you have “lost” your entire FW connection between the Mac and the device, go HERE:
    https://docs.info.apple.com/article.html?artnum=301852
    >Then, start again at my “step 1” above.
