Activity › Forums › VEGAS Pro › Video Not Appearing In Track View Or Preview
  • Video Not Appearing In Track View Or Preview
    Posted by Chrispy on January 1, 2006 at 8:55 pm
    I used Fraps Video to capture previews of one of my games and the resoultion I used was 1024×768. When i use the 1024×768 resolution the video tracks wont play although the audio does (the videos play in every other media device e.g winamp windows media player). In the “Track View” it shows a black screen for the whole clip as in the privew. I’ve tried changing the video properties to a larger resolution although this does not help either.
    Any help to fix this would be greatly apprecieated.
    Thank You
    Edward Troxel replied 20 years, 9 months ago 2 Members · 3 Replies
  • Edward Troxel
    January 1, 2006 at 9:49 pm
    Use GSpot to figure out what codec is actually being used. Locate and install that codec. Or run it through Virtual Dub and have it convert it to something Vegas can read.
    Edward Troxel
    JETDV Scripts
  • Chrispy
    January 1, 2006 at 10:54 pm
    Thanks alot buddy it worked well =).
    What do you reccomend is a good type to render as?
    Please include settings aswell.
    I dont mean to be a hastle but its the first time i’ve used this program =P.
  • Edward Troxel
    January 1, 2006 at 11:50 pm
    [Chrispy] “What do you reccomend is a good type to render as?”
    Depends on what you’re wanting to do! If you’re going back to MiniDV, then DV-AVI. If you’re going to DVD, then MPEG2. If you’re going to the web, probably WMV.
    This questions will require more information to answer accurately.
    [Chrispy] “I dont mean to be a hastle but its the first time i’ve used this program”
    You might want to take a look thorugh my newsletters (link under my name).
    Edward Troxel
    JETDV Scripts
