Activity › Forums › Adobe Premiere Pro › Video Noise in MPEG-1
  • Video Noise in MPEG-1
    Posted by Brian Bacheller on December 15, 2009 at 6:34 pm
    Hi – I’m currently having issues with MPEG-1. I can crunch out a 352×240 video that looks fine, but when I change the size to 400×300, I get video noise/flickering and the video almost gets a grainy analog look. I have tried a couple of different sizes, but the only one that produces good results is 352×240. I need the video to be bigger than that. Kicking up the black level helps a little bit…but that’s obviously not the right solution because it looks fine at 352×240…
    MPEG-1
    1000Kbps
    1.0000 Square Pixel
    I-Frame: 15
    Please let me know if you have any thoughts.
    Brian Bacheller replied 16 years, 9 months ago 2 Members · 2 Replies
  • Mike Velte
    December 16, 2009 at 11:45 am
    Both height and width should be divisible by 16.
  • Brian Bacheller
    December 16, 2009 at 3:57 pm
    Thanks for the reply Mike. I thought that might be it too…but I crunched one out at 400×304 and had the same issue…
    Those are both divisible by 16…let me know if you have any other thoughts.
    Thanks.
