Activity Forums Apple Final Cut Pro Legacy Video Monitoring problem
  • Video Monitoring problem
    Posted by Chris Fredricks on August 21, 2007 at 1:04 pm
    I’m trying to output my final cut project to a monitor like i’ve done several times. However when I go to:
    View > External Video > All Frames
    I click All Frames and it doesn’t work so I go back and Off is still checked. So basically it’s not letting me select All Frames.
    Anyone know why that might be?
    Chris
    Randy Johnson replied 19 years, 1 month ago 2 Members · 1 Reply
  • Randy Johnson
    August 21, 2007 at 4:50 pm
    that is a common occurance when the moniter is not connected but then you get a warning, I would think you are trying a to export using the wrong video playback option (found right under the external frames) it will default back to NONE with out warning then too.
