Activity › Forums › DSLR Video › Video monitoring and T2i
Posted by Rusty Shackleford on April 2, 2011 at 1:37 pmHow can I monitor video in the T2i as well record?
I tested with an HDMI from camera to TV, but I only get a signal to the TV, the signal doesn’t show on the camera when attached to TV.Brandon Morris
http://www.brandonmorris.comCanon T2i
13″ Macbook Pro (Mid 09) 8GB RAM 10.6Ganesan Gopal replied 14 years, 2 months ago 6 Members · 9 Replies -
Pete Burger
April 2, 2011 at 3:20 pmWhen an HDMI cable is attached, the camera switches off the lcd-screen on the cam but will record video to the card.
Rusty Shackleford
April 2, 2011 at 3:25 pmIs there to view on both? So the camera-op can see the T2i LCD and the director and producer can view on a TV or video village.
Brandon Morris
13″ Macbook Pro (Mid 09) 8GB RAM 10.6 -
Pete Burger
April 2, 2011 at 3:48 pmTo my knowledge, there’s no way of convincing the camera not to shut off the LCD, when plugging in an HDMI cable.
Shane Ross
April 3, 2011 at 4:07 amWhat Peter said. There is no way to do both. Further evidence that if you want a fully featured video camera, you need to get a fully featured video camera.
Shane
Read my blog, Little Frog in High Def -
Brent Dunn
April 4, 2011 at 8:07 pmThese are still cameras that happen to shoot video. They don’t have video mirroring, which is what you want. It also crops the image and puts up your camera info around the image.
I do have an external monitor which helps for focusing.
Brent Dunn
Owner / Director / Editor
DunnRight Films
DunnRight Video.com
Video Marketing Toolbox.netSony EX-1,
Canon 5D Mark II
Canon 7D
Mac Pro Tower, Quad Core,
with Final Cut StudioHP i7 Quad laptop
Adobe CS-5 Production Suite -
Rusty Shackleford
April 4, 2011 at 10:26 pmI have seen a few ways but it just adds on equipment.
I think it was hdmi out to a small black magic box that did SDI out to a tiny LCD mounted on camera for operator and another SDI out to video village. But that also needs external battery power for black magic box.I was hoping an adapter or magic lantern would work and save money and weight.
Brandon Morris
Dan Johnson
October 22, 2011 at 12:25 amI’ve read the with the HDMI to monitor set up the quality of the video on the monitor looks terrible once you hit the record button. Is that true?
Shane Ross
October 22, 2011 at 1:16 amThat is true. Because the HD signal then switches to a low res SD signal.
Shane
Ganesan Gopal
July 11, 2012 at 3:14 pmMagic Lantern on T2i can give clean 1080i output to record to Black magic hyperdeck shuttle for instance and shuttle can mirror the input on another hdmi out (through)
