Activity › Forums › Apple Final Cut Pro Legacy › Video Monitor Output
Posted by Sam Lesante jr. on February 6, 2009 at 6:28 pmHey fellow cows,
I had an employee do something on my nle and now when i park on the timeline it does not show up on my external monitor, it only shows what’s in the viewer.
How do you change that?
TIA
Sam
Sam Lesante Jr.
Sam Lesante jr. replied 17 years, 3 months ago 2 Members · 6 Replies -
David Roth weiss
February 6, 2009 at 6:35 pmHi Sam,
Here’s what to do:
1. Fire the employee
2. Tell me more about your monitoring setup. Is this your computer monitor or I/O out to a broadcast monitor?
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Sam Lesante jr.
February 6, 2009 at 6:49 pmSorry for being vague on the setup
It’s to my broadcast monitor, the a/ settings are ; seq. preset – dv ntsc 48khz, video playback aja kona 525i29.97 10 bit 720X486
Firing is too easy. Manual labor is better 🙂
David Roth weiss
February 6, 2009 at 7:04 pmOkay Sam,
In theory all you have to do is go to View>>Video Playback> and choose AJA KONA 525i29.97 10 bit 720X486. And, make sure that All Frames is checked in View>>External Video.
If these don’t work, then the offending employee did more bad stuff and we need to go deeper, perhaps into the Kona Control Panel.
Report back one way or the other, and good luck.
David Roth Weiss
Director/Editor
David Roth weiss
February 6, 2009 at 8:04 pmSam,
The easiest way to fix the KONA output if the quick fix won’t work is:
1) uninstall the drivers using the Kona uninstall utility that wan installed in the Kona Applications folder. And, then reinstall the latest drivers.
2) Change the settings per our earlier discussion.
Or, you could call the folks at AJA, who are nice and friendly. However, the uninstall and reinstall above is very quick and easy and should do the job.
David Roth Weiss
Director/Editor
