Activity Forums AJA Video Systems Video monitor calibration
  • Video monitor calibration
    Posted by Jack Kelly on April 9, 2007 at 5:18 pm
    I am planning to buy an AJA Xena LHe card and I’d like to know if it’s possible to profile and calibrate my analogue Sony BVM CRT video monitor using the LHe card and a suitable spectrophotometer? I use Premiere Pro 2, Adobe After Effects Pro 7 and PhotoShop CS2 all running on WinXP SP2.
    I very much like the look of the GretagMacbeth EyeOne Photo. Would I be able to use this to calibrate my Sony BVM video monitor?
    (And on a slightly different note – is it possible to use a GretagMacbeth chart to calibrate video cameras?!)
    Many thanks,
    Jack
    Jack Kelly
    London
    Dir / Prod / Camera
    Jack-Kelly.com – my homepage
    Tim Kolb replied 19 years, 5 months ago 2 Members · 1 Reply
  • Tim Kolb
    April 10, 2007 at 3:09 am
    With video CRTs (as opposed to computer CRTs), I usually have a nearby television engineer calibrate them as I don’t have the knowledge to get inside and tweak all those adjustments…
    You could use a probe and hand-adjust the face knobs to dial it in as close as possible, but I’m not sure how you would get the probe’s display information to the monitor…the probe needs to feed a signal to a display so it knows the exact values of the input to understand the differences present in the display’s output.
    I’m purchasing a used monitor right after NAB…I’ll probably be going through some of this myself…
    TimK,
    Director,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
