Activity Forums Adobe After Effects Video loop for Plasma Screen
  • Video loop for Plasma Screen
    Posted by Richard Prince on April 10, 2007 at 4:45 pm
    What’s the best way to create a DVD video loop (with no audio) of a number of stills?
    My issue is that my client needs this to play on one of these Plasma Screens:
    1. an NEC 42″ plasma monitor whose spec’s include: resolution:1024 x 768 aspect ratio: 16:9
    2. a Panasonic 42″ plasma monitor whose spec’s include resolution: 852 x 480 aspect ratio: 16:9
    I was thinking I would build and move each still in After Effects export a Quicktime movie to then cut the loop in Final Cut Pro
    Brian Charles replied 19 years, 5 months ago 2 Members · 1 Reply
  • Brian Charles
    April 11, 2007 at 1:16 am
    Depending on the DVD player you’ll need to set up for either HD or SD.
    I’ve done several loops like these for trade shows using DVD SP set to widescreen (16:9) and 480p.
    They look fine, perhaps not as crisp as true HD but my clients are using SD DVD players anyway.
    If there’s no HD or BluRay at the other end SD works well.
    My comps in After Effects are st to HD settings but my Compressor setting are for SD.
