Activity Forums Apple Final Cut Pro Legacy Video loop for Plasma Screen
  • Video loop for Plasma Screen
    Posted by Richard Prince on April 10, 2007 at 4:47 pm
    What’s the best way to create a DVD video loop (with no audio) of a number of stills?
    My issue is that my client needs this to play on one of these Plasma Screens:
    1. an NEC 42″ plasma monitor whose spec’s include: resolution:1024 x 768 aspect ratio: 16:9
    2. a Panasonic 42″ plasma monitor whose spec’s include resolution: 852 x 480 aspect ratio: 16:9
    I was thinking I would build and move each still in After Effects export a Quicktime movie to then cut the loop in Final Cut Pro
    Russell Lasson replied 19 years, 5 months ago 3 Members · 3 Replies
  • Russell Lasson
    April 10, 2007 at 4:53 pm
    Sounds like a good option to me.
    -Russ
  • Ernie Santella
    April 10, 2007 at 5:04 pm
    I might be better to create the QT files at the exact resolution of the monitor (then no ugly video scaling needed) then just play them on a small Mac Mini connected to the monitor. It might look much cleaner without the DVD compression. Just a thought.
    Ernie Santella
    Santella Film/Video Productions
    http://www.santellaproductions.com
  • Russell Lasson
    April 10, 2007 at 5:11 pm
    Do a quick test on a DVD player and see if it is acceptable. Niether one of the displays is true 720P HD. A good SDDVD should look acceptable and is by far the easiest solution.
    As I said, just do a quick test DVD and see if it will work or if you need to figure something else out.
    -Russ
