Activity Forums Apple Final Cut Pro Legacy Video level change on quicktime from FCP
  • Video level change on quicktime from FCP
    Posted by Sean Eunson on June 2, 2008 at 11:08 pm
    I am in a sequence that is in 1920 x 1080 ProRes. I export out a quicktime from Final cut Pro 6.0.2. The show has lower 3rd titles that were created in Photoshop (CS3). Every time I come to a title in the Quicktime (7.3.1 Pro) it pops the white level up slightly. I bring the same file into Final Cut and it does not do this.
    I look at my show in final cut , it does not do this. Every title does it in the Quicktime (ProRes HQ, not using conversion, Quicktime movie , self contained)
    I open it in After Effects (CS3) it does not do it
    I open it in Avid (which down converts it to DV space) I dont see it.
    I take it to another machine – the quicktime- I dont see it(Quicktime 7.3.0)
    Yet on this machine I made it on its clear as day. in the Quicktime file.
    Is it the version of Quicktime?
    – OS 10.4.11
    Machine is a Mac Pro (october 2007) 4 gigs of Ram. Quad
    Sean Eunson replied 18 years, 3 months ago 2 Members · 2 Replies
  • Rafael Amador
    June 3, 2008 at 9:18 am
    FC changes the Gamma of your picture to let you see how will look in a CRT.
    You can set QT to do the same. In the Preferences> Enable FC Studio Compatibility.
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Sean Eunson
    June 3, 2008 at 6:29 pm
    Solved. Thank you very much. It was a setting in Quicktime – Visual settings-change to composition (settings in lower left) it defaulted to dithering for some reason. Note- when you change to composition it will resize video , just make video smaller or larger and it will snap back into place. Save file and you good to go.
    Thank you once again, this forum is amazing.
