Activity › Forums › Apple Final Cut Pro Legacy › Video Level Adjustments
  • Video Level Adjustments
    Posted by David M on November 13, 2006 at 11:15 pm
    I would like to control video levels while I’m digitizing material in the Clip Settings tab in Log and Capture. Although I’ve checked the video box in Clip Settings and the manual says it’s possible to adjust video levels using the waveform monitor and vectorscope I’ve had no luck. The manual also says that the video level adjustments are disabled when capturing DV video via firewire . I’m using AJA Kona to bring DV component into my system. Is there any way to enable the video level adjustments.
    David Battistella replied 19 years, 10 months ago 2 Members · 1 Reply
  • David Battistella
    November 14, 2006 at 6:04 am
    You can only adjust the incoming levels if you use a composite input. Composite is the least quality way of bringing in footage.
    Maybe you can just drop a 3 way CC real time affect on the clips in the timeline to bring the overall levels down. This is a very normal practice.
    David
    Peace and Love 🙂
