Activity Forums Boris FX Particle Illusion “Video” layer not changing in “edit mode”
  • “Video” layer not changing in “edit mode”
    Posted by Michelinok on August 25, 2007 at 6:44 pm
    I don’t know if it’s possible but I’ll explain my problem.
    I’ve added a video in the background layer of my little project, is there a way to see the current video frame while manually changing the current key? I mean…. i need to move some emitters looking at the background…
    At the moment, i run the project,pause the project,then move the emitter…it’s so boring doing this!
    I hope i’ve explained my problem well….. my english is so bad!
    Michelinok replied 19 years ago 2 Members · 3 Replies
  • Elvis Deane
    August 26, 2007 at 3:47 pm
    Are you saying that you want to move the emitter as the background video is playing? If that’s it, then right-click on the emitter on the stage and choose Record Position.
  • Michelinok
    August 26, 2007 at 4:54 pm
    Not exactly, i mean that when i slide the “project slidebar”, i want to see the correct photogram changing in the background
  • Michelinok
    August 26, 2007 at 6:07 pm
    Found…it was only a problem of my background video….changed it to an xvid (instead of full uncompressed frames) and works ok!
    Thank!
