Activity Forums Apple Final Cut Pro Legacy Video is flickering during exporting
  • Video is flickering during exporting
    Posted by Steve Framework on February 23, 2007 at 10:13 pm
    Hello,
    I’ve edited some video in Final Cut that will be for broadcast. Playback in Final Cut looks fine. I will then export the commercial using Quicktime Conversion.
    The problem is when I watch it as a Quicktime file the video is jittery during transitions, and seems to flicker a bit…with small lines showing.
    I’m not sure if my question is a Quicktime one, or perhaps I’m exporting it wrong out of Final Cut.
    Any thoughts anyone?
    Steve Framework replied 19 years, 7 months ago 2 Members · 2 Replies
  • Enzo Tedeschi
    February 23, 2007 at 10:26 pm
    If the file looks fine on an external video monitor, then you will be OK. What you are describing sounds like interlacing. It can appear as jagged lines on you computer monitor, especially where there is a lot of movement.
    Check it on a video monitor to be sure.
    Enzo Tedeschi
    ____________________________
    Editor
    http://www.outpostpps.com
    Sydney, Australia
    YouTube Channel – http://www.youtube.com/outpostpps
    Check out the Outpost Video Podcast – http://www.outpostpps.com/podcast/
  • Steve Framework
    February 23, 2007 at 10:51 pm
    Thanks for writing.
    To answer your question…it is appearing on a TV as well when I look at it.
    How do I fix the interlacing?
    Thanks for your help…
