Activity › Forums › Adobe Premiere Pro › Video Info
Video Info
Posted by Sc2006 on July 27, 2006 at 11:12 pmIn the project panel, some clips are listed as 720×480 (.9) Others are 720×480 (1.2) What is the number in the brackets and how can I ensure imported video is the same resolution?
Andre Gagnon replied 20 years, 2 months ago 2 Members · 4 Replies -
Andre Gagnon
July 28, 2006 at 12:52 am720X480 (1.2) means that the pixels forming the images in your clip are rectangles that have a 1.2(H) X 1.0(W) Width/Height form factor. These result in a Widescreen TV format
720X480 (O.9) means that the rectangles have a 0.9(W) X 1.0(H) form factor. These result in the normal TV format: 720*0.9/480 usually designated as the 4:3 format.
Note that in both cases the resolution is the same 720 pixels X (Width) by 480 (Height). Only the shape of the pixels varies between the two formats.
Andre Gagnon
July 28, 2006 at 12:59 am[Andre Gagnon] “720X480 (1.2) means that the pixels forming the images in your clip are rectangles that have a 1.2(H) X 1.0(W) Width/Height form factor. These result in a Widescreen TV format”
Sorry the first sentence should read:
720X480 (1.2) means that the pixels forming the images in your clip are rectangles that have a 1.2(W) X 1.0(H) Width/Height form factor. These result in a Widescreen TV format
Sc2006
July 28, 2006 at 1:07 amThanks Andre,
I am guessing that I can ajust a clip by interpreting the footage?
SC
Andre Gagnon
July 28, 2006 at 4:43 am[sc2006] “I am guessing that I can ajust a clip by interpreting the footage?
SC”
That’s the way to do it!
