Activity Forums Adobe After Effects Video in QT looks good, video in AE looks bad.
  • Video in QT looks good, video in AE looks bad.
    Posted by Edward Tasick on November 7, 2009 at 10:51 pm
    I have a Quick Time movie with animation compression that looks great when played in Quick Time player. When I import the same movie file into After Effects It looks blocky and terrible. I have seen this before but have never figured it out. I’m thinking maybe its some kind of codec issue. Any help with this would be appreciated. Thanks
    James Hawkins replied 16 years, 8 months ago 5 Members · 14 Replies
  • 14 Replies
  • Keith Mcgregor
    November 7, 2009 at 11:46 pm
    I’m gonna kick myself but, do you have the downsample
    factor set to full? The display resolution? If it truly
    is aimation compressed it should look immaculate in AE.
    I’m thinking you know what your doing but sometimes we overlook
    the little things. -K
    Reality? What did you make it?
  • Edward Tasick
    November 8, 2009 at 12:49 am
    yeah the downsample factor and display resolution are set to full? there is definitely something more going on here. Still cant figure it out. I know I have seen this before. there has to be someone out there who has run into this and figured it out.
  • Steve Roberts
    November 9, 2009 at 1:40 pm
    Yikes!
    There’s a clue: in the ugly version, the downsampling isn’t equal, that is, the pixels aren’t square.
    What info is shown for the footage in the Project window?
  • Mike Johnson
    November 9, 2009 at 4:36 pm
    I have been experiencing the exact same thing. Animation codec. Plays fine in QT, blocky (though not as bad as yours) in AE. In the program window, clicking on the clip shows the proper info except for where it should list the codec: I get seemingly random letters – qelr in this case.
    Also, audio that should be there does not play. I can hear it in QT, but not AE (and yes, my playout settings are correct). Showing the waveform gives a flat line. I’m not trying hijack this post, just giving extra info on the exact same problem files.
    Finally, if I take these files to a laptop that is running the same versions of everything I have no problems. The only difference is that the problem machine has a Kona LHe and has the Cinema4d aec plugin installed.
  • Steve Roberts
    November 9, 2009 at 7:36 pm
    Have you guys tried different codecs as a workaround? TGA sequence, PNG sequence, 8-bpc uncompressed …?
  • Edward Tasick
    November 9, 2009 at 7:46 pm
    this is the info shown for the footage in the Project window
  • Edward Tasick
    November 9, 2009 at 8:04 pm
    Excellent description Mike, we are definitely experiencing the exact same thing. I too am getting the seemingly random letters (qelr) along with the missing audio and if I use a different computer everything works fine. So now there are two people with the same problem. Someone out there must know what is going on here.
  • Steve Roberts
    November 9, 2009 at 8:07 pm
    “qeir”? Are you sure this was rendered to the animation codec? What does the Info say in QT Player?
    If it’s in an AJA codec, it should be 720×480 or 720×486, right?
  • Edward Tasick
    November 9, 2009 at 8:19 pm
    Yeah I ended up exporting all my video out of QuickTime with Motion Jpeg B compression and it works perfectly. But as I’m sure you know a work around like that will only work so many times before a more permanent solution must be found.
  • Edward Tasick
    November 9, 2009 at 8:44 pm
    Yeah, I’m sure it was rendered to the Animation codec. Below is a screen grab of the QuickTime inspector for the movie in question. I also did some tests exporting the movie out of QuickTime using the Animation codec and I still get the same problem.
