Activity Forums Adobe After Effects Video in After Effects
  • Video in After Effects
    Posted by Benjamin Asnis on May 20, 2010 at 9:27 pm
    I am working with Sony EX-3 footage in After Effects and notice a flicker on export. The compressor is XDCAM EX 1080i60 (35 Mb/s VBR). I tried interpreting the fields setting them to separate upper fields first in After Effects and that did not help. My composition setting is HDTV 1080 29.97. What am I doing wrong? I’ve had the same problem in the past with standard def footage that was uncompressed 10 bit as well.
    Ben
    Benjamin Asnis replied 16 years, 4 months ago 2 Members · 3 Replies
  • Benjamin Asnis
    May 20, 2010 at 11:14 pm
    There is a strobing effect on movement sort of a 24p look when it was not shot in 24p. It is 29.97. I’m looking for a way to maintain that video look. There is no darker or lighter effect though.
    Ben
  • Michael Szalapski
    May 21, 2010 at 4:40 pm
    Does the raw footage play back the way you like and it’s just in AE that you see this problem?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Benjamin Asnis
    May 21, 2010 at 6:00 pm
    The raw footage plays back fine in final cut pro, it just doesn’t look right after I make movie in After Effects.
    Also if this helps at all the Sony EX-3 shoots full HD.
