Activity Forums Adobe Premiere Pro video import into premiere pro got problems
  • video import into premiere pro got problems
    Posted by Ho Wai leng on April 20, 2011 at 7:22 am
    I was doing keying and adding in animation in after effect cs3 , then export as mov animation. I import the file into Adobe premiere pro cs4 to edit, the video come out some problem like this. When i checked back the video then i render in ae, there was no such problem, but when i import into pr, the problems come out. How should i deal with this ?
    Ho Wai leng replied 15 years, 5 months ago 2 Members · 2 Replies
  • Kobi Versano
    April 21, 2011 at 9:11 am
    I’m not sure I understand exactly what is the problem.
    Can you be more specific?
  • Ho Wai leng
    April 21, 2011 at 2:58 pm
    when you see the second, third and fourth images , can you see around the people there are some lines or weird images , they should look like the first image . These are few frames in the video , this problem comes out in others parts too .
