Activity › Forums › Apple Final Cut Pro Legacy › Video grossly interlaced
  • Video grossly interlaced
    Posted by Connor Rochester on November 7, 2010 at 6:53 pm
    Hi, I am having some technical trouble with Final Cut/ and or my computer. My camera is a Sony HDR-HD5, which shoots on 1080i. But the transition between camera, to capture, to Final Cut is very drastic.
    The footage looks absolutely perfect when looking at it on the camera. When I’m importing it into Final Cut however, the Capture window shows a much more muted and lower contrasted image. Then, even worse, when I watch the footage back on my computer after uploading it, whether in Final Cut or even in Quicktime, the footage is disgustingly interlaced, to the point it actually warps the image.
    I know there is an option to “De-interlace” footage through filters, but by the time I have de-interlaced everything, it looks very fuzzy (better than interlaced, but still irritating). Does anyone know what is going on or have any suggestions?
    John Christie replied 15 years, 10 months ago 2 Members · 1 Reply
  • John Christie
    November 7, 2010 at 8:13 pm
    Interlace footage ALWAYS looks bad on a computer monitor. If your going to go back out to tape and watch it on a TV that’s OK. But if your end result is web or computer use, consider the Too Much Too Soon filters:
    https://www.mattias.nu/plugins/
    Blend fields does a great job converting 60i to 30p
    Can’t speak to your contrast issues, if you’re coming in via firewire from HDV, then FCP isn’t doing any processing of the footage, just transferring the data.
    Cheers
    John Christie
