Activity Forums Apple Final Cut Pro Legacy Video goes fuzzy when I just move it down?!?!
  • Video goes fuzzy when I just move it down?!?!
    Posted by Josh Johnson on October 3, 2005 at 11:43 am
    I have a some very nice clean dv footage. Over that I have two slugs cropped to 15 for a letter box. I thought the letterbox gave me freedom to move the video up and down but whenever I do the video goes fuzzy (like a prerender or something).
    Has anyone else had this probem?
    Does anyone know how to fix it?
    I’m using a DV/DVCPRO timeline but I tested everything in an uncompressed 10-bit timeline and the results weren’t much better.
    Frame size is 720 x 480
    Pix aspect is NTSC – CCIR 601 / DV
    Field Dominance is lower (even)
    Video Processing is set to Render all YUV material in high-precision YUV.
    Frame Rate is at 100%
    Resolution is also 100%
    I’m on FCP 4.5.
    Dual 2.5 G5
    4 gig ram.
    Using an IO.
    Thanks for your help.
    Kevin Monahan replied 20 years, 11 months ago 4 Members · 4 Replies
  • Walter Biscardi
    October 3, 2005 at 12:21 pm
    if you’re playing it in realtime, it will degrade until you render it out.
    Also, when you move video up or down in NTSC, you must move it to an even scan line or it will look degraded. In the Motion Tab, ensure that the Center setting has an even number on the second setting. Such as 0,10.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
    G5 Dual 2.0, AJA Kona 2, Medea FCR2X
  • Josh Johnson
    October 3, 2005 at 12:38 pm
    That fixed it.
    Just moved it to an even scan line.
    THANKS!!
  • Winston Cely
    October 3, 2005 at 5:37 pm
    When I have to adjust position and screen size, I get everything in the general area I need it for the rough cuts, and then go back and even out all the number before my big final render. I do have a question though, when using LiveType or motion (to import later into FCP 5.0.2) do I need to keep those numbers even in LiveType or Motion? This is why I ask: When working in those programs, I get my text or graphics right where I want them, so that I’m not moving the clips position/scale in FCP. So since I’m not adjusting anything in FCP, I should be alright, right?
    Winston A. Cely
    Editor
    Envision Response
    Seattle, WA
  • Kevin Monahan
    October 3, 2005 at 6:06 pm
    I’d still be mindful of the odd/even scan line issue. You may want to do a test.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
