Forums VEGAS Pro Video Getting Stuck After Changing Frame Rate
  • Video Getting Stuck After Changing Frame Rate
     Garin Emerick updated 2 weeks, 2 days ago 1 Member · 1 Post
  • Garin Emerick
    May 11, 2022 at 10:57 pm
    So whenever I change the video from the frame rate 29.970 (NTSC) to 59.940 (Double NTSC) some clips in the preview get stuck, it’s kinda hard to explain but I’ll try my best to explain to you guys what it does.
    So the VFX I have applied to the video is working just fine and not lagging/stuck, the effect I’ve added was the S_Shake video effect that is applied to the video. Like said it works just fine but the video that had the effect applied to it is frozen and it gets locked up in place after a few seconds into the clip. So it works fine for a couple seconds then it gets frozen. I don’t know how to explain this further but hopefully you guys will understand what this issue is.
    I am a beginner of video editing and I can’t figure this out at all. I don’t know what I should do I’ve looked it up on the internet and typed in things I could think of what the issue was but to no avail I saw nothing that showed me anything about the problem I have. Now, this is my first time posting in Creative Cow so I’d like to be shown what to do when posting here. But the main problem is this issue with my video whenever I adjust the video’s frame rate. I hope this makes sense, if it doesn’t come and ask me good questions so I can try to tell you the most I can for you guys to understand what is happening. I can also give you guys a video showcasing the issue if you want. Please let me know what I can do so that way I don’t have this problem anymore, it has been frustrating to me a lot. Thanks!
    -CFalcon075
Viewing 1 of 1 posts
Log in to reply.
