Activity Forums VEGAS Pro Video FX not showing on the final product
  • Video FX not showing on the final product
    Posted by Samantha Jordan on June 28, 2015 at 7:55 pm
    Hi 🙂
    I am fairly new to Sony Vegas Pro 13, and I have recently encountered a problem.
    After rendering my video, I played it back and the FX don’t show at all.
    When I view the video on the Sony Vegas program, the FX does show, but not on the final product.
    I would really appreciate it if you would provide your support. Thank you!
    Graham Bernard replied 11 years, 2 months ago 3 Members · 7 Replies
  • 7 Replies
  • Graham Bernard
    June 28, 2015 at 8:15 pm
    The only way I can think this has happened is that just prior to Rendering you’d inadvertently BYPASSED the FX.
    Odd…
    Grazie
  • Bob Peterson
    June 29, 2015 at 2:22 am
    What FX did you use, and how did you view the results of the render?
  • Samantha Jordan
    June 29, 2015 at 3:07 am
    I used the Darker, more Contrast FX, and I viewed it through Windows Media Player.
  • Graham Bernard
    June 29, 2015 at 4:10 am
    [Samantha Jordan] “I used the Darker, more Contrast FX, and I viewed it through Windows Media Player.”
    OK, as a Test, apply the SONY Pixelate “Large” preset and see if that gets applied. Do a short selection, say a 5 second sample, shouldn’t take you too long to do. Do you see the Pixelate effect?
    Grazie
  • Bob Peterson
    June 29, 2015 at 4:09 pm
    OK, you used the Sony Brightness and Contrast FX with a Darker, more Contrast Preset. That is certainly visible on my system although Media Player is a bit darker than Vegas.
    What file name and format did you render to, and what directory is that file in? How did you get Media Player to access and play the file?
  • Samantha Jordan
    June 29, 2015 at 10:35 pm
    Hmm… that’s weird. I do see the Pixelate effect, but not the one I had previously.
  • Graham Bernard
    June 30, 2015 at 6:41 am
    [Samantha Jordan] ” I do see the Pixelate effect, but not the one I had previously.”
    If you can see the results of the Pixelate FX then this is GOOD news. This indicates that the registry of all your FXs are running smoothly. You could try another FX just to be assured – yeah?
    Now, onto the possible solution for your changed Contrast and “Levels” not apparent or showing, or appear to be not showing. This is a well worn road.
    Here’s a good COW Thread to read, with some great samples from Plamen Petrov to demonstrate POSSIBLY what you’re getting – or rather – not getting: Plamen Petrov – Weird Exporting/Playback Issues – Look At The Snapshots!
    Toodles
    Grazie
