Activity › Forums › Apple Final Cut Pro Legacy › Video from Canon DSLR, having problems with dropped frames
Posted by Hannah Beers on September 27, 2011 at 6:27 pmI’ve been working on a Macbook Pro in Final Cut Pro mainly with Canon camcorder footage – nothing flashy, and no problems. Recently we invested in a Canon T3i and so I imported DSLR footage for the first time.
I could hardly play the footage for a few seconds before getting dropped frames messages. Thanks to forums like this one, I decided to get a new external (a 3TB G-Drive w/ firewire) and playback is drastically better but still freezes up enough to be irritating.
What else should I try? I’m not familiar with the drive or the camera – maybe a different format to import footage in? Or a setting on the external, or within Final Cut?
Thanks.
Hannah Beers replied 14 years, 11 months ago 5 Members · 16 Replies -
David Roth weiss
September 27, 2011 at 6:39 pmSearch the forum and you’ll see 10-zillion posts on this subject. Video from DSLRs must be transcoded before editing to an editing codec that FCP likes, like ProRes 422.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comDon’t miss my new Creative Cow Podcast: Producing Episodic TV with “24” Producer Michael Klick:
https://library.creativecow.net/weiss_roth_david/Podcast-Series-1_Michael-Klick/1POST-PRODUCTION WITHOUT THE USUAL INSANITY ™
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Hannah Beers
September 27, 2011 at 6:52 pmThanks for the reply. And I promise I did look through the forum, but I’m not that fluent in formats or technical language and I wasn’t sure which diagnoses apply to my scenario.
What should I use to transcode my footage? FCP or another program?
Shane Ross
September 27, 2011 at 7:03 pmUse LOG AND TRANSFER (need to download and install Canon EOS plugin…oh, T3i…you’d have to hack it too)…or use MPEG STREAMCLIP…COMPRESSOR…5DtoRGB…
I have a tutorial here on Log and Transfer, with links to how to hack:
Tapeless Workflow for FCP 7 Tutorial
Shane
Read my blog, Little Frog in High Def -
Tim Baker
September 27, 2011 at 8:06 pmHey Hannah,
My workflow works really well for me…do a web search for MpegStreamclip…it is a stand alone piece of software that is priceless. I use it many times per week.
You can drop your footage in it and transcode in a batch to just about anything that you want. I work mainly with Panasonic as my primary source of footage so I usually go to DVCProHD with it.
It seems to be a little faster and less troublesome than using FCP for the transcode.
Tim Baker
Chameleon Mobile Video Productions
(239)849-3295
“It is not the light at the end of the tunnel that we should seek…it is the courage to take the next step in the dark that we must find.”
Hannah Beers
September 27, 2011 at 8:06 pmI used Compressor to translate the files from Quicktime to ProRes 422, but now the dropped frames are worse than ever! Any other suggestions?
David Roth weiss
September 27, 2011 at 9:53 pm[Hannah Beers] “I used Compressor to translate the files from Quicktime to ProRes 422, but now the dropped frames are worse than ever! Any other suggestions?
“Now we’re into phase #2 – what type of hard drive are you playing the video from? You are using a separate media drive right? And, it’s not a USB drive, right?
David Roth Weiss
Los Angeles
Hannah Beers
September 28, 2011 at 12:56 pmI have a brand new 3TB G-Drive, connected via firewire. I have another drive for running Time Machine, so on the GDrive I have my FCP files as well as older, completed projects. Anything else I should look for?
David Roth weiss
September 29, 2011 at 5:24 pmAre any of your firewire hard drives plugged in using firewire 400 cables, or are all firewire 800?
David Roth Weiss
Los Angeles
