Activity Forums Apple Final Cut Pro Legacy video filter routing?
  • video filter routing?
    Posted by Geoffrey Plitt on June 9, 2008 at 10:47 pm
    i’m having trouble understanding video routing.
    i’d like to use 2 chroma keys on top of each other– one to filter out green, and another to further filter out another color.
    when i put 2 chroma key effects on a clip, they don’t seem to “chain”. i want the output of one filter to go into the input of the second, like this:
    orig clip –> 1st chroma key removes one color –> 2nd chroma key removes the other
    (result: both colors removed)
    but it seems like the 2nd chroma key uses the original clip as input, so that the result on that clip only shows whichever chroma key is on top:
    orig clip –> 1st chomra key removes one color (good so far)
    (starts from scratch) orig clip –> 2nd chroma key removes other color
    (result: only 2nd color removed)
    is there any filter routing so i can chain filters?
    -g
    David Bogie replied 18 years, 2 months ago 4 Members · 3 Replies
  • Colin Mcquillan
    June 9, 2008 at 11:37 pm
    Try a nest. Put first filter on the clip, then nest the clip, now add 2nd filter to the nest
    Colin McQuillan
    Van BC
    Octo 3.2, 8gig, 8800GT, 2×23″ ACD, 2TB G-Speed eS, Kona LHe, JVC DT-V24L1UA, Mackie 1202-VLZ3, KRK Rokit5’s….
    MBP 2.4, 4gig , 2xLacie Quadra 500gig….
  • Jeremy Garchow
    June 9, 2008 at 11:50 pm
    Nest might do it, or try putting a null filter in the middle. Something like desaturate @ 0% will do. Also, try using another keyer that isn’t the chroma keyer.
    Jeremy
  • David Bogie
    June 10, 2008 at 3:25 pm
    Getting the best chromakeys out of AE or FCP (or media 100) for me has usually been a case of applying keying filters to multiple copies of the same clip, not multiple copies of the keyer to the clip.
    bogiesan
