Activity › Forums › Adobe Premiere Pro › Video File Still Too Big After Export to Desired Format
  • Video File Still Too Big After Export to Desired Format
    Posted by Lauren Kaiser on November 2, 2017 at 3:50 pm
    So I just want to preface this post by stating I am relatively new to this and acknowledge this may be a dumb question, but I could really use some help.
    I edited a video in Adobe Premiere and it is just over 3 hours long. I exported it from Premiere using the YouTube 1080 HD setting as that is the format I want it in. The problem is the file is 22GB and I need it to be much much smaller, maybe 10GB max. How can I make the file smaller without losing too much quality?
    In Adobe Media Encoder even changing it to YouTube 720 looked as if it would only reduce the file size by about 1GB. I’m currently trying a few things in HandBrake, but I’m feeling a little lost. I’d ultimately like to use Adobe Media Encoder, but like I said I’ve already exported to the YouTube 1080 HD setting so trying that again wouldn’t make my file smaller right?
    Thanks for any help you can provide!
    Lauren Kaiser replied 8 years, 10 months ago 3 Members · 5 Replies
  • Shane Ross
    November 2, 2017 at 7:19 pm
    [Dave LaRonde] “Three hours is an EXTREMELY long time in YouTube — they may not even accept something that long. “
    I guess you haven’t seen the 10 hour loops on YouTube of things like Nyan cat or other inane songs. Or the fireplace that goes for 16 hours. They have LONG videos on the Tubes
    Shane
    Little Frog Post
  • Jeff Pulera
    November 2, 2017 at 8:51 pm
    Aside from making a video shorter, the only way to make the file smaller is to reduce the bitrate. Period. I think the YT 1080 default rate is 16, so for instance 8 should cut the file size in half. Of course, this will reduce quality also, so do some SHORT sample exports and review to see what you think.
    Depending on the content of your video, perhaps 720p HD quality is acceptable? Since there are less pixels per frame to encode (compress), you will be able to use a lower date rate than with 1080p and still keep the quality up.
    Using VBR 2-Pass encoding will maximize the efficiency of the encoding.
    Jeff Pulera
    Safe Harbor Computers
  • Lauren Kaiser
    November 6, 2017 at 4:15 pm
    Thank you Jeff! This was tremendously helpful. If you don’t mind I do have one follow up question. When changing/reducing the bit rate should I change both the target bitrate and the maximum bitrate to the same number?
    Lauren
  • Jeff Pulera
    November 6, 2017 at 5:10 pm
    The MAX bitrate would normally be set a bit higher than the TARGET. The term target in this case means average. Having a higher max bitrate helps when there might be sudden changes in the video content which might spike the data rate.
    For instance one might use Target 8, Max 10.
    Jeff Pulera
  • Lauren Kaiser
    November 6, 2017 at 6:03 pm
    Again, very helpful! Thank you so much.
