Activity Forums VEGAS Pro Video File size
  • Video File size
    Posted by Hugo Sanchez on July 18, 2010 at 5:49 pm
    Hello , i’m new to vegas 6.0, i need,help. I open an mpeg file with ize of 100megs (35 mins), and cut out about 10 minutes worth of video, and when i redner it turns into a 6 GB file? please help. I know i need to change the settigs, but why won’t it just save with same settings as original. also I don’t know how to get the settings of the originals.
    thank you.
    Daniel Frost replied 16 years, 2 months ago 3 Members · 2 Replies
  • Danny Hays
    July 18, 2010 at 9:11 pm
    IAfter you add the clips in the time line, they will show up in your project media tab. click on one and just below it at the bottom of that window, it tells you the properties of that clip. You can also use G-Spot, a free utility that will tell you everything you need to know about that clip. Just open G-Spot and drag a clip on it. Here’s a ling to G-Spot. Hope this helps, Danny Hays
    https://www.headbands.com/gspot/v26x/index.htm
    Get the top one.
  • Daniel Frost
    July 26, 2010 at 2:38 pm
    What kind of video type are you rendering to?
    File types like avi will be very large, try rendering to MP4 or WMV, they generally have higher compression so smaller file size but are still good quality.
