Activity Forums VEGAS Pro Video file plays fine in Sony Vegas 11 but not in 12
  • Video file plays fine in Sony Vegas 11 but not in 12
    Posted by Oren David on December 14, 2013 at 3:48 pm
    Hello,
    I have some in-game recorded videos and I am using Sony Vegas to edit them.
    So far, I have been using Sony Vegas 11, but lately I found out there was a newer version (12) and decided to give it a try.
    However, there’s a problem: When I import my video file into version 12, all I see is just a green screen. The audio plays fine, but the screen is just solid green. I have tried importing multiple clips, but they all had the same result.
    I then tried to load the exact same files in version 11, and there it worked perfectly.
    So my question is: what can I do to let those videos load correctly in version 12?
    Here’s some info that you might find useful:
    I never installed any codecs, all I have are “default” ones (I guess that’s what they are, right?)
    I am running Windows 8.1 64bit. My Sony Vegas 12 version is 12.0.770, and my 11 version is 11.0.701.
    A GSpot analysis of the file:
    https://puu.sh/5MmGQ.png
    If you need anything else, just tell me.
    Oren.
    Steve Rhoden replied 12 years, 9 months ago 3 Members · 2 Replies
  • Matt Carlson
    December 14, 2013 at 7:11 pm
    With each update of Sony Vegas 12 the tolerance for non-standard MP4 sizes has been getting worse. Build 770 of Vegas 12 has finally broken completely.
    Any MP4 that has a size that is not equally divisible by 4 will show green. (1366 / 4 = 341.5) If you can find Build 367 of Vegas 12 all MP4s were working. MP4s of standard sizes (1280×720 etc) still work correctly.
    I am not sure if this is intentional or not because for four revision updates Sony has not tried to fix it.
  • Steve Rhoden
    December 14, 2013 at 8:31 pm
    You are correct Matt, build 714 is what iam currently using
    and the only one i choose, because it is rock solid, and handles
    MP4 quite well… So that’s the version you should try Oren.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
