Activity Forums Adobe Premiere Pro Video feed to second monitor
  • Video feed to second monitor
    Posted by Julian Roberts on January 1, 2011 at 1:36 pm
    Hi – and Happy New Year all.
    I am using PPro CS5 on a Mac Pro, with three monitors connected. If I have PPro on monitor 1, is it possible to have real time playback on monitor 2. I’m pretty sure I managed to do this in CS3 using the Desktop playback settings, but whatever I do I only seem to see an option for DV – i.e. using an external deck or camera.
    In Encore I get options for preview on monitors 2 and 3. Perhaps I’m doing something wrong in Premiere…?
    Thanks very much
    Julian
    Vince Becquiot replied 15 years, 8 months ago 2 Members · 7 Replies
  • 7 Replies
  • Vince Becquiot
    January 1, 2011 at 7:00 pm
    Hi Julian,
    Maker sure the monitor is enabled in your display settings and uncheck “Mirror displays”, so that it becomes extended. It should then show up in Premiere.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Julian Roberts
    January 1, 2011 at 7:26 pm
    Thanks Vince. All 3 displays are visible to the Mac and the ‘mirror’ option is unchecked. Which sequence settings should I use please?
    Regards
    Julian
  • Vince Becquiot
    January 1, 2011 at 7:45 pm
    The sequence settings shouldn’t matter.
    You should be able to hit the contextual menu on the top right side of source/program panel and choose the display to use under playback settings > External device
    Vince Becquiot
    Kaptis Studios
  • Julian Roberts
    January 1, 2011 at 8:17 pm
    How strange. I only get the option on ‘none’ or ‘DV’. Yet, in Encore I can see all 3 monitors….
  • Vince Becquiot
    January 1, 2011 at 9:38 pm
    Strange indeed. How are your outputs configured?
    Try using your second card for extended monitors only. I’m assuming you are using 2 graphics cards?
    Vince Becquiot
    Kaptis Studios
  • Julian Roberts
    January 1, 2011 at 11:10 pm
    I’m on a Mac Pro – so one graphics card supports three monitors.
  • Vince Becquiot
    January 1, 2011 at 11:25 pm
    Unfortunately, I’ve only used our MBP this way so I can’t test it on a Mac Pro. I would make sure that the latest drivers are installed. Is this an ATI Radeon card?
    Vince Becquiot
    Kaptis Studios
