Activity Forums VEGAS Pro Video Effects dont render well on the edges of the video ???
  • Video Effects dont render well on the edges of the video ???
    Posted by Viki Kumar on July 15, 2006 at 6:02 pm
    Hi ive noticed,
    Be it blur or a wave ripple. It doesnt carry uniformly over the entire frame. there is a band at the bottom and top where it looks like its a mirror strip. I hope you can get what i mean. For example lets say you have text scrolling in from one of the sides of the video. Entering into the video frame. And youve also applied blur to it. so that only when it reaches the middle of the video frame does it become clear. Now you will find that as the text is moving in in a nice soft horizontal blur. When the text has some basic shape change it creates a processing error type of vertical line streaking out from the text shape. Like say the cavity within a d. This is very tough to understand. But just create a text layer (itallic style). Then shift it out of the video frame. Now make it glide in from the left edge onto the middle of the screen. Also apply a blur video effect to the text. Keyframe so the blur clears up when the text is dead centered. You will see what i mean. Watch the text get in from the left. As it enters inside the frame you will see a television fluctuation scrolling type of effect on the blur. You will see darkened bars scrolling the smooth blur. Spoils the entire effect. I know this is not a bug. Basically the blur is processing the text as it enters that way. Any workaround to avoid this ??
    Viki Kumar replied 20 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
