Activity Forums Adobe After Effects Video effect
  • Michael Szalapski
    February 10, 2010 at 3:45 pm
    You want to emulate this look? Most people try very hard to make sure their video doesn’t look like this.
    If you choose the wrong settings under interpret footage, it will look like this.
    If you’d like to actually do it with an effect, duplicate your footage layer, offset it in time by a frame or two (or three, or more…test it out) and apply Effect>Transition>Venetial Blinds to the top layer
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Stuart Elith
    February 11, 2010 at 2:27 am
    It just looks like interlacing to me… a blown up screenshot so the fields look a lot bigger/fatter.
    If that’s the case, yes, you will notice it most when there is fast movement.
    Read the AE help files for a lot of great info about interlacing, and you will be able to introduce it into your footage in the Interpret Footage options.
