Activity Forums VEGAS Pro Video dislpay setup
  • Video dislpay setup
    Posted by Carlo Simone on August 1, 2006 at 2:55 pm
    Hello all again,
    I just purchased an older Panasonic BTLH-1800 Broadcast pro flat panel with an HD add on. Only problem is, the HD add on only supports composite inputs. My question is, what device would I need to broadcast from Vegas to my monitor to view HD or even SD for that matter if my only option is composite.
    Thanks..
    Gary Kleiner replied 20 years, 1 month ago 3 Members · 2 Replies
  • Tevya Washburn
    August 3, 2006 at 2:32 am
    Are you sure it’s composite? Because unless my lysdexia is just kicking in, composite is an old-school VHS-quality (RCA connectors). If it’s component (three separate lines for one video signal) then it can carry HD. In which case I assume you’d just need some kind of adapter?
    –the Fiddler
  • Gary Kleiner
    August 3, 2006 at 9:07 pm
    A DeckLink card would be the way to go.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
