As a side note, last week I tried upgrading to 5.03, QT 7.03, and my SD video output disappeared on edit to tape to Digi Beta, but was fine when I returned to 5.02 which is the current setup
Answer: Here’s how to test your RAID with a real clip:
1) Set up your project with a KONA 2 easy setup (type for easy setup menu; make sure the “show all checkbox” is checked).
2) Create a new sequence (). A new sequence will appear in the FCP browser.
3) In the FCP browser, double-click on the sequence; the new sequence will appear in the FCP timeline window.
4) Click on the Effects (tab) in the FCP browser.
5) Go to the Video Generators folder, and drag the appropriate Bars and Tone effect onto the new sequence.
6) Go to the Video Filters -> Video folder and drag the Timecode Generator Effect onto the video track of the new sequence (burned in timecode).
7) From the FCP menu bar, go to FILE -> EXPORT -> QUICKTIME MOVIE.
8) Give it a name and make sure the rendered clip is stored on the RAID.
9) From the FCP menu bar, go to FILE -> IMPORT, and select the clip that you exported in step 8.
10) Create a new sequence and drag the bars and tone clip onto the new sequence.
11) Hold Down the
Make sure that your tool bench is closed (i.e. the audio mixer and/or the waveform) and is not hising behind your viewer, browser, canvas, timelines, or bins. This has tripped me up in the past.
