Activity › Forums › AJA Video Systems › Video decks for Xena HS
Posted by James Goodman on January 20, 2006 at 5:52 amI use Prem 1.5 with a Canopus Storm and a Sony DSR-25
With Prem 2 I plan on a new capture card and want to be HD ready so what are my choices for Decks that I can use with the Xena HS ?
Andrew Kramer replied 20 years, 7 months ago 3 Members · 4 Replies -
Andrew Kramer
January 21, 2006 at 2:18 am“These BNC connectors are for connecting serial digital video input and output devices (respectively). SD signals are 10-bit or 8-bit SMPTE-259. HD signals are 10-bit or 8-bit SMPTE-292.”
Any decks outputing this format will be compatible with the card. There are only a couple of decks that do what you need, which one are you looking at?
Also You’ll need to upgrade to premiere 2.0 for the HS card to work.
Andrew
James Goodman
January 21, 2006 at 2:48 amThanks Andrew
I have ordered the upgrade to Prem pro 2 as part of my video suite upgrade (Pro version) and I was aware that I will need a SDI deck with RS422 control but I am having a hard time finding what decks are out there. You mentioned that I have a couple of choices – what are they ? -
Kevin Christopher
January 21, 2006 at 3:18 amDigibeta DVW-500
Beta SP BVW-75D
DVCAM/DV DSR-1500 with SDI option, JVC BR-DV6000 with SDI option.
HD-CAM and HD-CAM SR
DVC Pro HD
etc etcThats all for a Friday Night.
Kevin
