Activity Forums Adobe After Effects Video conversion – help
  • Video conversion – help
    Posted by Geo Lam on May 26, 2008 at 4:20 pm
    I have a 40 second video to export for web (for this video, about 15mb)
    H264 quicktime mov render from Aftereffects works well but quality is a little lacking
    so i’ve exported as a quicktime animation and looking for some software
    from what i’ve read, squeeze and clean are good.
    but as i am a beginner (if you couldn’t tell), i cant afford either of these programs
    i looked at quicktime pro, but was a bit iffy after reading several reviews on it
    any recommendations?
    Geo Lam replied 18 years, 3 months ago 2 Members · 2 Replies
  • Tielman Dewaele
    May 27, 2008 at 12:13 am
    H264 at best quality is the best option you have and should normally be good quality for the web.
    Do you have Flash?
    T.
    Quad Core Intel Mac Pro
    Duo Core Intel MacBook Pro
    Final Cut Pro 6, After Effects CS3, Cinema4D V10
    Illustrator & Photoshop CS3
    https://www.t-bloggy.blogspot.com/
  • Geo Lam
    May 27, 2008 at 11:23 am
    Hmm no, I don’t have Flash. But anyway, I think I can’t use Flash anyway.
    And yeh, H264 is good but the file size is much bigger than required.
    Temporary solution, I used Premiere and exported it at 40% quality which made it 14.5mb
