Activity › Forums › VEGAS Pro › Video clips out of time sync with preview window?
  • Video clips out of time sync with preview window?
    Posted by Jamie Watts on June 25, 2019 at 9:26 pm
    Picture examples:
    Before: https://ibb.co/5rsWsGh
    As you can see, the timeline is within the clip, but the preview shows nothing.
    After: https://ibb.co/yk3mFF6
    Now I’ve moved the timeline further along and the beginning of the clip shows in the preview window.
    It’s quite difficult to explain. It always behaves like this, regardless of the video or picture I try to edit. This makes precise editing (without the “quantize frames” ticked) impossible.
    I’d be grateful for any information. Thanks.
    Jamie Watts replied 7 years, 3 months ago 4 Members · 20 Replies
  • 20 Replies
  • George Dean
    June 26, 2019 at 12:29 am
    Jamie, use the free app Mediainfo in text mode and post the specs of your source media please.
    Best Regards……George
  • Jamie Watts
    June 26, 2019 at 12:45 am
    Thank you kindly for responding.
    I could/would do that if it was just this clip, but it appears to do this with all media sources. ☹ I recently experimented with a fresh picture from Google and it still did it.
  • Ole Kristiansen
    June 26, 2019 at 8:42 pm
    Vegas version ?
    Full computer Specs. ?
    MediaInfo of your recordings ?
  • Jamie Watts
    June 26, 2019 at 10:34 pm
    Hello. Thanks kindly for responding.
    Vegas Version:
    VEGAS Pro 16.0
    Computer Specs:
    OS Name Microsoft Windows 10 Home
    Version 10.0.17763 Build 17763
    Other OS Description Not Available
    OS Manufacturer Microsoft Corporation
    System Name BEAST
    System Manufacturer Alienware
    System Model Alienware Aurora R8
    System Type x64-based PC
    System SKU 08F7
    Processor Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz, 3192 Mhz, 6 Core(s), 12 Logical Processor(s)
    BIOS Version/Date Alienware 1.0.3, 01/04/2019
    SMBIOS Version 3.1
    Embedded Controller Version 255.255
    BIOS Mode UEFI
    BaseBoard Manufacturer Alienware
    BaseBoard Product 0R3FWM
    BaseBoard Version A00
    Platform Role Desktop
    Secure Boot State On
    PCR7 Configuration Binding Not Possible
    Windows Directory C:\Windows
    System Directory C:\Windows\system32
    Boot Device \Device\HarddiskVolume1
    Locale United States
    Hardware Abstraction Layer Version = “10.0.17763.529”
    User Name BEAST\rando
    Time Zone GMT Daylight Time
    Installed Physical Memory (RAM) 16.0 GB
    Total Physical Memory 15.8 GB
    Available Physical Memory 8.85 GB
    Total Virtual Memory 20.6 GB
    Available Virtual Memory 9.68 GB
    Page File Space 4.75 GB
    Page File C:\pagefile.sys
    Kernel DMA Protection Off
    Virtualization-based security Not enabled
    Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
    Hyper-V – VM Monitor Mode Extensions Yes
    Hyper-V – Second Level Address Translation Extensions Yes
    Hyper-V – Virtualization Enabled in Firmware Yes
    Hyper-V – Data Execution Protection Yes
    MediaInfo of video clip:
    Format: MPEG-4
    Format profile: Base Media
    Codec ID: isom (isom/iso2/avc1/mp41)
    File size: 2.76 GiB
    Duration: 2 h 53 min
    Overall bit rate: 2 282 kb/s
    Writing application: Lavf58.19.100
    Format: AVC
    Format/Info: Advanced Video Codec
    Format profile: High@L4.1
    Format settings: CABAC / 4 Ref Frames
    Format settings, CABAC: Yes
    Format settings, Reference frames: 4 frames
    Codec ID: avc1
    Codec ID/Info: Advanced Video Coding
    Bit rate: 2 150 kb/s
    Width: 1 920 pixels
    Height: 864 pixels
    Display aspect ratio: 2.222
    Frame rate mode: Constant
    Frame rate: 23.976 (24000/1001) FPS
    Color space: YUV
    Chroma subsampling: 4:2:0
    Bit depth: 8 bits
    Scan type: Progressive
    Bits/(Pixel*Frame): 0.054
    Stream size: 2.60 GiB (94%)
    Writing library: x264 core 157
    Encoding settings: cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=18 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=2150 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=31250 / vbv_bufsize=31250 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
    Codec configuration box: avcC
  • Ole Kristiansen
    June 27, 2019 at 9:24 am
    Hi
    So you got a Alienware Aurora R8 pc ! Your graphic card ? What kind of drives ?
    Can you show us your timeline settings ? Your clip i 2h53m – what happens if you try with clips around 10min. ?
  • Jamie Watts
    June 27, 2019 at 6:03 pm
    Hello.
    Please note that I’m not too knowledgable with computers and mostly taught myself how to use Vegas.
    Graphics Card:
    NVIDIA GeForce GTX 1080.
    Type of drive:
    SSD.
    Timeline Settings:
    I’ve never deeply tinkered with the timeline settings; all settings are usually default. The only things that are ticked are Enable Snapping, Snap to Markers and Snap to All Events. I turn Quantize to Frames off when I want to be more precise with editing, but the problem still exists either way. As for the time, it’s set at “Times and Frame”.
    I tried using a short video clip and picture. I also did a brand new install of Vegas. It’s still the same.
  • Ole Kristiansen
    June 27, 2019 at 6:43 pm
    Hi !
    It was easier to make a short video than to write a lot!
    Do you create the Vegas Pro 16 timeline the same way I show in the video?
    https://www.youtube.com/watch?v=m5WZILPJq8A&feature=youtu.be
    Best,
    Ole
  • Jamie Watts
    June 27, 2019 at 8:11 pm
    Hello. Thanks kindly for responding and I watched your video.
    I don’t think I’ve ever done what you showed in the video, no, I’ve always just dragged the video clip into the program and started editing from there.
  • Ole Kristiansen
    June 27, 2019 at 8:57 pm
    “Codec ID: isom (isom/iso2/avc1/mp41)”
    Is your clip from screen recording using OBS, maybe it crashed while recording and made a corrupt file !
  • Jamie Watts
    June 28, 2019 at 7:06 pm
    Hello.
    I honestly don’t know. A friend converted the clip for me using their software months ago and gave it to me.
    I did try your way of creating a timeline too. No luck; it still shows black in the preview window when I’m within the beginning of a clip. It’s the same with other clips and pictures I’ve tried too.
