Video Card and Capturing Video
Posted by Dave Petteruto on May 12, 2011 at 6:26 pmDoes the video card come into use during video capturing in Vegas?
Dave P.John Rofrano replied 15 years, 4 months ago 2 Members · 6 Replies -
John Rofrano
May 12, 2011 at 6:46 pm[Dave Petteruto] “Does the video card come into use during video capturing in Vegas?”
Not unless you purchased a video card that captures like the Quadro SDI Capture. Otherwise, no… capture cards are usually separate from video cards. (Actually, that’s not a video card that captures but rather a capture card that links directly to your video card)
What kind of capture are you doing?
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Dave Petteruto
May 12, 2011 at 6:59 pmThe reason I am asking is this–About a month ago my editing computer started freezing whenever I played a video file in any of my video viewing software (quicktime, windows media player & a Nero player)also freezez using Blufftitler (which uses video card). I can put the video on the Vegas timeline and view it with no problems. Because of this I was thinking I was having problems with the video card. Now today I am trying to capture some video via firewire using Vegas 7 and 9 (which I do all the time) and it is freezing up at randow times (after several attempts). So I was wondering if it could be video card related.
Dave P. -
John Rofrano
May 12, 2011 at 8:08 pmWell… if you have the video preview on then I guess it’s using the video card to display the frames it’s capturing. Try turning off the video preview and see if it helps.
~jr
Dave Petteruto
May 12, 2011 at 8:27 pmThanks John, I’m trying a capture without the preview on right now. We will see what happens.
Dave P. -
Dave Petteruto
May 12, 2011 at 9:43 pmDisabling the preview seemed to solve the freezup problem during capture. Thanks John. Now I need to figure out whats wrong with this damn computer!
Dave P. -
John Rofrano
May 13, 2011 at 10:52 amYou’re welcome. Yea, you should not be having problems like that but I’m glad that solved it for you for now.
~jr
