Activity Forums VEGAS Pro video capture question
  • video capture question
    Posted by Enrique Orozco on January 17, 2009 at 6:26 pm
    maybe dumb question… is there a way to “program” my video capture to STOP when finishing capture from a tape ? … sometimes analog tapes (Canopus converter) with no timecode settings ….
    best wishes for 2009….
    Enrique Orozco R.
    iDEA DigitalVideoStudio
    Graham Bernard replied 17 years, 8 months ago 3 Members · 2 Replies
  • John Rofrano
    January 17, 2009 at 10:56 pm
    It will stop at the end of a DV tape because it has transport control and can sense the stop. The problem with analog converters like the Canopus is that they generate their own timecode and continue to generate it long after the tape has ended so Vegas has no way of knowing that the analog tape stopped.
    Maybe you can use the batch option and set the in and out points for an hour and then capture the in/out which would capture for an hour (or whatever time you set) and then stop.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Graham Bernard
    January 20, 2009 at 8:16 am
    Kelly Chien aka “Chienworks”, created a piece of s/w that was designed to capture via VidCap analog streams from an already “setup” tv stream. I have used it. And I would think that with a bit of planing – you NEED to sync your capture “recipe” to your PC clock – and leave the tape running, that this would be doable too.
    Grazie
