Activity › Forums › Avid Media Composer › video capture off by 1 frame
  • video capture off by 1 frame
    Posted by Baz Leffler on May 23, 2012 at 7:44 am
    I have found many reports here about this problem but no solutions.
    I am trying to capture from a Sony JH 3 deck using a Blackmagic Multibridge Extreme on MAC as PAL. The deck is auto detecting correctly in Avid.
    It is capturing 1 frame too early. I can not find any adjustment for it like FCP has.
    It is the same on all 3 of my MC6 and Symphony systems.
    Can anyone direct me to a solution as I desperately need precise frame accurate capture.
    cheers
    Baz Leffler replied 14 years, 3 months ago 2 Members · 3 Replies
  • Baz Leffler
    May 23, 2012 at 8:29 am
    And to add an update – edit to tape (HDW1800) occurs 1 frame late and leaves a black hole of 1 frame. That means that the playback start is 1 frame late as it is the deck that is doing the actual edit from the timecode the Avid sends it.
  • Daniel Edelman
    July 2, 2012 at 7:52 pm
    Hi Baz,
    I’m experiencing a similar problem with my Multibridge Eclipse, specifically during digital cut. Did you ever find a solution?
    -Dan
    Dell Precision Workstation T5400:
    Dual Quad Core Xeon 2.33Ghz
    8GB ECC Buffered RAM
    nVidia Quadro FX 3700
    500GB 7200 RPM System Drive
    2TB Internal SATA RAID 0 (2x 7200 RPM Burrered Drives)
    Avid MC6
  • Baz Leffler
    July 3, 2012 at 12:33 am
    Hello Daniel
    I reported the problem to Avid and they wanted me to PAY MONEY before they would look into THEIR PROBLEM!
    I have since STOPPED using any of my 4 Avid systems and gone back to FCP7 which DOES do frame accurate edit to tape.
    I have now reported the problem with Blackmagic who are investigating the problem.
    It may help if you also report it to Blackmagic support.
