Activity Forums VEGAS Pro Video Capture is way to long and I need to trim it…Whats the best output
  • Video Capture is way to long and I need to trim it…Whats the best output
    Posted by Dholzemer on August 8, 2006 at 1:30 pm
    I have a 2hr tape that I was capturing into vegas 4, I started it walked away and promptly forgot about it. 13hrs later, the capture autostops and pretty much totally fills up my hard drive….a major oops.
    My question is, I want to cut off the end (the last 11hrs)and re-export the file so I can use it later.I don’t really want to have to recapture it.
    Does anyone have a recommendation on the best file format to render it too without much or any quality loss? I thought about uncompressed AVI, but I know those files are huge as well.
    thanks for any help!
    david
    Dholzemer replied 20 years, 1 month ago 2 Members · 2 Replies
  • Edward Troxel
    August 8, 2006 at 3:10 pm
    Assuming you captured DV-AVI, drop that 2 hours on the timeline and render to DV-AVI. Since you’re making no changes, it will simply COPY that section of the file to a new file. Then you can delete the huge file.
    Edward Troxel
    JETDV Scripts
  • Dholzemer
    August 9, 2006 at 6:36 pm
    Many Many Many Many thanks!!
    You saved me many gigs and lots of time!
    david
